Creates aliases to execute any ExtremeXOS command, including any options, arguments, and redirection.
| alias_name | Specifies an alias name for the command. |
| command | ExtremeXOS command that you are creating an alias for. |
N/A
To be recognized, the alias must be the first word in the string typed at the shell prompt. Substitution does not occur if the alias name string occurs anywhere else. Aliases are only recognized by the EXSH shell session in which they are created.
Executing the command alias (with no other arguments) displays a list of current aliases. Executing the command alias alias_name displays the command that will be substituted for alias_name.
To delete aliases, use the command unalias.
After an alias has been created, you can auto-complete the alias name or display possible aliases along with regular commands by pressing the TAB key. You can tab-complete arguments that follow commands corresponding to an alias.
Creating an alias using the name of an existing ExtremeXOS command
overrides the original meaning of that command. For example, executing alias download "download image 102.3.10.5" allows
you to simply type download image_name to download your ExtremeXOS image
from the 102.3.10.5 location . However, if you then want to download a bootrom file, the
command download bootrom 102.3.10.5filename no longer functions correctly. Such
an alias can be disabled temporarily and the original command behavior restored by preceding
it directly (with no spaces in between) with a backslash, \download bootrom 102.3.10.5filename This
temporarily overrides the alias definition and uses the original command.
To create an alias for a command that contains quoted strings within it,
use a backslash. For example, if creating an alias "cr" for the command configure vlan default description "This is the default
VLAN", use the command alias cr
"configure vlan default description \"This is the default VLAN\"".
sh ps at the prompt is not equivalent
to entering “show version
process”.Aliases are only available in the shell session in which they are created. When you exit the shell your aliases are lost. To create persistent aliases, you need to add the aliases to the script exshrc.xsf that you must create using the VI editor and save in the /usr/local/cfg folder.
The following example creates an alias named "set" for configure commands:
alias set "configure"
You can now substitute the command set for all configure commands. For example, you can type set vlan vlan_name tag tag instead of configure vlan vlan_name tag tag.
alias mycmd "configure policy profile 1 name Extreme pvid 1000 pvid-status enable tci-overwrite enable auth-override enable forbidden-vlans 2 cos-status enable cos 2 untagged-vlans 2 egress-vlans 200"
Typing mycmd now
executes the command configure policy profile 1 name
alias alias mycmd='configure policy profile 1 name Extreme pvid 1000 pvid-status enable tci-overwrite enable auth-override enable forbidden-vlans 2 cos-status enable cos 2 untagged-vlans 2 egress-vlans 200' alias set='configure'
This command was first available in ExtremeXOS 22.3
